Hi all,
I got a problem with my tablet Huawei M2-A01W.
The tactil screen is defective. It means that it works but I need sometimes to tap with my finger several time before I can get the correct answer.
This is pretty annoying while I’m writing something long because i can take a long time to finish it.
All the area of the screen are reacting the same way, the screen is clean, I tried to reset it from factory parameter but this doesn’t change. I don’t see any impact on the screen and have a protection cover around it all the time.
Any idea or suggestion to solve it ?
Thanks
Thanks
